kempesh said:
The TOB squeeked when the car was in gear, just as he says his is currently doing.
K
I dont think he said this (I did not interpret his comments as such, at least).
In your case K, when you had too much preload, if you rested your foot on the clutch pedal, the noise should have gotten worse (per what you described). His noise goes away, right?
Also, one should never have the pedal adjusted in such a way that one inch of pedal depression causes the clutch to disengage. A clutch in that situation would slip and burn up in short order.
I dont think there is a solid understanding of the dynamics at work here - your posts contradict eachother and I dont think it is much else than perhaps a lack of familiarity with terminology (I keep posting not to butt heads, but to see if we can reach the bottom of this). I like to think I have a decent handle on clutches.
In your case K, did you have a new stock quadrant and pawl installed? Or did you change hooks on the aftermarket quadrant? Those are the means to adjust the cable at the quadrant (as you referred to). Most folks should not have to ever adjust the clutch at the quadrant when using an aftermarket quadrant. This is why you have a FWA or adjustable cable.
What I am wondering is if you have a FWA. If you do, this might be where we are running into confusion. Turning the FWA in (tightening it), adds slack (lowers the point of engagement). I had a fleeting thought that this was where confusion was being introduced. THis is where 'tightening' actually 'reduces' preload.
If the TOB is firmly loaded against the PP, it will start squeaking after a little time (it is not unlike driving all the time with the pedal depressed a little ways on a car with a normal adjustment). That could have been what happened to you. As you loaded the TOB more and more, the noise got worse. That is not normal for a properly functioning TOB. And once you backed it off so the TOB was barely touching the PP, the noise subsided. Correlation is not causation (because it happened to someone once, does not mean it is the same for the next guy).
Very simply stated, when I do a clutch adjustment, I leave it loose and start it up. I can hear the TOB rattling around. I just tighten the FWA/adjustable cable till that noise subsides. Then I get in and feel where my point of engagement is. It is normally close to the floor as I have barely introduced any preload. I get the pedal where I want it (generally with a point of engagement closer to the floor) and lock it in. This method allows one to start from one end of the spectrum and adjust it properly (or to one's liking - the final adjustment is personal preference).
I still stand by my above-comments about 96Beast's adjustment probably being too loose (going off the limited info provided). Kempesh, we might have to agree to disagree on this one. :cheers:
