I recently replaced the thermostat in in 5.0 and since i replaced it, it has a slow leak from the bottom of the water neck. I cleaned both gasket surfaces then reinstalled the water neck with a new gasket and tightened it and it is still leaking. I then removed it and put some rtv on the intake manifold part of the thermo housing. I then reinstalled it and it is still leaking slowly. What would you all suggest i try to stop this annoying little leak. Ive got another gasket and was gonna try that , or just skip the gasket and put rtv on both mounting surfaces.
