Test Electric Fan Amperage?
510 views 5 replies 4 participants last post by  tmoss
#1 ·
Is there a way to test how many amps an electric fan draws? I have a Taurus fan laying around, but wanted to see how many amps it draws. Thanks-Dan
#2 ·
There are two ways:
1. Amp-Clamp, it is a probe that clamps around the wire and measures the current. You must already have a meter that measures current, usually they don't come with the meter unless its a serious meter like a Fluke, but can be bought seperatley.
2. You can hook up your meter in series with the hot lead, assuming it measures DC current.
Just get a car battery, hook the ground wire to the ground post of the battery, the + wire to one lead of the meter, and the other lead to the battery.
#4 ·
Before you try that make sure your meter is fused for thay high of amperage. Most DVM are fused around 20amps.
I used a amp meter clamp and my SN95 pulls about 50amps on start up and about 36-38 continous.
