Just needed to see if anyone is running tailpipes on a fox body without going over the axle as usual. Post pics if you have this setup as I'd like to see how to run them. THANKS!
Visit www.performanceautosport.com and look under "customer's cars"... There is a 1993 Cobra R on there with the best side exhaust setup I've ever seen...
I can see how the exhaust routed like that would work on a drag car only, but not on a true daily driven street car. Driving in areas, such as southern missouri where the roads are loaded with sharp curves, dips, and steep hills, the exhaust would simply be ripped right off of the car on the first hill you pop over due to your suspension going to full travel.
When the exhaust is only mounted an inch or so from the bottom of the rearend in those pictures, then you are asking for trouble on the street. A good pothole would ruin the exhaust, as a result of longer travel in the rearend forcing the exhaust down. A nasty set of train tracks, even an extremely hard stop will cause the nose to dive and the rearend of the car to lift, resulting in an extended rearend which would in turn rip the exhaust off of the car.
Thank you .I am truely impressed with how well it looks under your car. thumbs up!
