OK, I got my T5 back together but now it will bind up when turning it clockwise (facing the front of tranny). If you turn it the other way it is fine. I also notice that it will not bind at all if the tail housing is off or even loosened up. As soon as you torque down the tail housing bolts it will bind again. You might get a few turns out of it then it binds. I did not change one thing in it, just took it apart to replace some seals and the front bearing retainer, but this is happening with the original retainer. BTW it will do it wil the top cover on or off, I tried all combinations trying to eliminate stuff. WTF??
