My '97 has an odd popping sound comming from the rearend that just started recently. The car is running stock control arms both upper and lower, stock shocks, and "C" springs with 1 coil cut from the top as per the instructions included with the springs. The springs have been in for a good while now so I highly doubt that they are the problem. When I get the car rolling from a complete stop there is a "POP" that comes from the right rear it sounds like and you can feel it as well. Once the car is going I no longer hear it but if I stop again and then get the car rolling again it does it once more and so on. Seems like it makes this noise once the suspension is loaded up. If I really really slowly get the car rolling than I can't hear or feel it but anytime I take off just normal I can hear it/feel it.
Any ideas what it could be? I have made sure that things were tight up under there. What do you guys torque the control arm bolts down to?
