Surging Idle - Possible ecu related?
Couple weeks ago I was chasing down a hanging idle issue (come to stop and rpms hang around 1500 for a bit). Usual suspect is IAC but mine was clean as a whistle, however I tried a spare w/no change. I then tried checking voltage on the TPS and noticed it was 1.1v. So I tried adjusting it by enlarging the holes and got it down to .96v. Started the car & everything seemed fine, but forgot I still had the test leads connected to back of the Ground & Signal wires. Engine vibrations caused the test leads to accidently bump each other while running and the idle started to go batsh!t surging. I pulled the test leads and shut it off, disconnected the battery and started over. But ever since then I have been chasing a reoccurring surge that I can't lock down. I've done a few base idle resets since. I can get the car to idle perfect at its 840rpm per my tune. But the moment I shut it off & restart car //OR// just start driving immediately after reset, the surge returns and I can't get it to go away until I clear the computer & do another reset.
While its surging, I've done the following to see if anything improved the idle
I've pulled codes, nothing other than 511 'chip'. I've disabled my chip to go back to the stock ECU and surging there too. I've checked for Vacuum leaks galore, all hoses are less than 4yrs old, but did a smoke test anyway and nothing found. Concerned I jacked the TPS when the test leads touched, I ended up replacing the oem one with a new NTK just in case. So far I've also tried two oem IACs, two oem MAFs, and two TPS, all with no change.
Current setup on the car
Now, the car drives fine at mid & WOT. Has no issues with stalling out. The idle surge is pretty minor (((ATTACHED))) bouncing from 840-1000 but no higher, no lower. Just annoying really. I have not done a Cylinder Balance yet, but haven't had any suspicions thus far. Other than the hanging idle when this started, car was fine until those two test leads bumped each other.
I'm a a loss here., if its ecu related, how can I tell? I've also noticed that my IAC is only getting 4v at idle and increases as the throttle is raised. Is that normal? I couldn't remember if the IAC was variable up to 12v or not.
- Disconnect IAC = No change, surging continues, but reconnect & momentarily goes up, but eventually drops & surging continues
- Disconnect TPS = No change, surging continues, same for reconnect, getting correct 5v at reference wire & .99v at signal w/tb set to .010
- Disconnect MAF = No change, surging continues, same for reconnect
- Disconnect PVC = No change, surging continues, same for reconnect
- Air Bleed valve = No change fully opened or closed or partially, surging continues
- Disconnect Spout = (IAC connected) car stalls out
Cobra upper/lower
65mm tb with stock air box
stock 19lb injectors w/kirban afpr (35psi @ idle / 45psi'ish with vac off) <-adjusted this, didn't seem to make any difference
Walbro 190lph
Edelbrock Performer heads with 1.6rr
Melling SYB-51 cam, very close to stock lift, but little more duration
Underdrive pulleys
Shorty Headers with O/R H
NTK O2 sensors (about 4yr old w/less 7k miles)
Stock Autolite plugs & gap
Timing set at 10deg
