Steeda Crank Pulley?????
1 reading
405 views 4 replies 4 participants last post by  97BlackSteed
#1 ·
If I were to only put on the Steeda crank pulley and not the whole set, do I need to get a different belt?
I am not interested in getting charging problems and slow electro/mechanical devices in my car like the windows when you put an alternator pulley on..
#2 ·
u can put the crank pulley and water pulley with the stock alt pulley, the steeda one is not much diff and the tenionser will take up and slack. Put on the main two, thats where and gains r found, and if u really dont wanna put on the alt pulley dont
side note i dont think u'll have any charging problems, i know i dont or cooling problems with the water pump pulley.....if you want to still just use the crank pulley you will need a different belt
#3 ·
Can someone do me a big favor. Will you measure the Steeda crank pulley, and just give me a rough number on how big it is. A friend and I are trying to find out why my crank pulley is so small, yet looks stock with the drilled areas for balancing.
#4 ·
I measured 4 1/4"
Hope that helps.
