I have a 92 Mustang GT 5.0 that is mostly stock except for a bigger throttle body and CAI. The smog pump is going out and instead of replacing it I would like to just remove the entire smog system. Can someone out there tell me how to do this? I need someone to tell me what equipment to remove and what additional things I need to do to accomplish this besides just removing parts, if any. I need someone to lay out everything from A to Z on what to do?
1) Will I need to reprogram the computer or buy some sort of component to install after I remove the smog components?
2) I'm sure I'll need a shorter serpentine belt once I remove the smog pump. Do I need some sort of delete kit with a idler pulley or can I just buy a shorter belt?
3) Will I need to modify any wiring? I read about how to do this years ago, but I don't remember what the article said to do.
If my memory serves me correctly, all I need to do is remove the smog components without any additional modification...Is this correct?
4) If all I need to do is remove the smog components, can someone tell me what component to remove and where exactly they're located? I know where the smog pump is and the hoses that are connected to is are obviously part of the smog system. But what other components do I need to remove?
Thanks in advance for your help....
