Guys: Your information has helped me lots in the past with other projects. I just recently purchased a 1989 coupe 5.0 5 speed. It is in great condition and factory original down to the air box silencer, the factory intact exhaust system and the distributor boot etc...The ashtray door even works perfectly.
Let me start by saying that I am impressed with what these cars can do from the factory with knowledge and tuning alone. I want to take this coupe as far as can without putting parts on it.
I cannot use any visible modifications, I need to keep the 100% original appearance. I will add 3.73 gears (since I may add Nitrous later and 4.10's will be too much) and a short throw shifter, as well as remove the silencer to the airbox (Unnoticeable mods). I'll be running 10 hole rims possibly widened in the rear and narrowed in the front.
My tuneup consists of: The Downs Ford kit which includes motorcraft stock copper plugs, 9mm ford wires, brass cap and rotor, fuel filter PCV valve & motorcraft oil filter. My questions are:
Should I spend the $$ on a K&N panel filter or just run a paper one?
Stock spark plugs AR25's or different?
I'm going to cut back the electrodes on the plugs and index them. Yes?no?
What gap should I run?..I'll be running a hotter coil but it'll look factory.
What timing should I run? I know each motor is slightly different.
What fuel pressure should I run? I'll be swapping on a kirban regulator at some point.
I'll be running a short belt at the track
I'll be running drag radials on the stock 10 holes. What is the biggest/tallest tire I can fit with stock quad shocks and tailpipes? 265/60/15?
Should I run a bigger TB on the stock intake? Like a 65mm ford unit?
Should I run a bigger Mass Air meter? Is there a factory looking one?
I'm not looking to port the heads or intake yet, but will some smoothing on the TB/intake entrance help?
Will this thing ever run 13's like this? I wont power shift it until I have a backup transmission ready
Sorry for all the questions..I hope I provided enough information. I'll post pics soon.
