hello, its been a while since this post was started but ive been having some shifting related issues, basically my 89 foxs t5 shifts a bit notchy especially in the lower gears (1 and 2) NO grinding whatsoever, mostly everything is all new (clutch, tob, pilot bearing etc and has a new quadrant and firewall adjuster) but every so often at stops and lower speeds it doesn't want to shift into first or retirees way more effort then i would like. Now I know this sounds like a dragging clutch, however its a bit more complicated. i have had it up in the air and recorded the trans output/drive shaft. as i was shifting through gears (engine running) i kept shifting until i got it to the point where it doesn't want to shift into first. i would have needed to really force it to go in but i did not. I kept pushing on the shifter just before it shifted (never actually put it into 1st). I replayed the video at this point and you can see the drive shaft want to turn quite a bit (the wheels never spun when shifting i did that check before). That would indicate the clutch slightly dragging causing the input to slight spin the cluster shaft which is constantly spinning the 1st gear and as i am trying to shift into 1st the sycnro is working way harder to slow down the 1st gear and is not able to slow it down due to the slight drag. Here where it gets confusing, if the clutch is dragging even a small amount wouldn't i grind going into reverse? i do not grind when going to reverse (if i jam it in right away when pressing the clutch then yes i will but that's normal) but after a few seconds when the clutch is technically supposed to spin down it does not grind or anything. so how could it be dragging in 1st and not create a grind in reverse?
the reason i replied to your comment is becasue when i had the trans apart (the issue was there before i had it apart, i took it apart because of this) i noticed my input shaft had absolutely 0 side to side play and im pretty sure the end play was 0 as well. It did not move a hair, now i see that you mentioned the preload could affect the shifting, i will need to confirm my end play as i do not remember 100 percent how much movement it had for that but my side to side was like a solid rock 0 movement as well as my tailsft bushing is the original and the yoke is fairly worn. When i was shifting with the trans out sometimes it shifted a bit hard as well but that was without the lever.
so here's some key things i would like to mention,
new clutch came with tob and pilot bearing (was a cheap LUK kit) could the pressure plate or disc be faulty?
new pivot ball stud
clutch is fully adjusted (no mater how i adjust it mostly the same)
Any insight would be greatly appreciated!!!
