Ok after coming into more money I have decided to go the blown route now that I can afford it not really but I can make it happen. Ok Ive been doing some research on which blower I would like to buy in a month or two once bank account is ready. Anyways I was thinking of doing a S-trim but for a little more I could get a Novi 2000 which will be more than enough once I build my bottum end. I can only afford the blower 42lb injectors in tank pump and mass air meter and tune and chip for now so I wont be running higher boost than the stock pulley on the paxton comes with what is that by the way? I figure once my funds are recovered I can build the bottum end and turn up the boost than. Is there a power pipe that works with the Novi Ive seen a bunch for S-trim but none for novi. Also how hard was install on a DOHC anyone do it therselves. Ok well thanks for the info Im pretty much sold but just push me over the top thanks. Also anyone using the charge cooler system with the novi 2000 how is it does it work well installation how was it?
