Wondering if theres any advantage to going electeic pump on a weekend street car. Looking at putting on single turbo and moving alternator to drivers side down. Electric pump sure looks clean. Anyone using electric?
Yes, they are generally very reliable as long as you buy a decent quality one and use the proper controller setup. A PWM controller with a soft start circuit greatly increases the motor life on the pump. There are now actually quite a few cars on the road these days with electric water pumps doing all the engine cooling.It's the electric water pump good for daily use?
Not certain what Baskin is currently offering, but I have one of his older Contour Fan/controller combos that came with a seprate circuit to run an electric pump. The pump circuit uses the same temp probe as the fan. I don't have an electric pump so that feature is not being used but at least it's available should I want an electric pump in the future.I just got a 2sp from dcc to soft start my electric fan, wonder if both can be controlled by it?
