Saleen vs Cervini 93 Foxbody
1.8K views 8 replies 3 participants last post by  ssancya
#1 ·
Hi guys,I’m looking for input for those of you that have used or installed and painted one, either, or both on a build. Which is better in terms of ease of installation, quality, and longevity. I’m leaning heavily towards true Saleen however I want to make the right decision.
#7 ·
Cervinis kits are top notch ,I'm a 20 year painter /body man , I can tell you that you will have to do quite a bit of preparation to paint them , I've painted/installed many cervinis kits and they are as close to perfect as you'll get ,but... they are not scuff and paint , they HAVE to be sanded down with 180 grit or at least 220 grit and an adhesion promotor for plastics sprayed on , ( rattle can version will work ), and a urethane primer needs applied with multiple coats ,sanded out after drying and then sealed and painted /cleared , if these steps aren't taken the paint will blow off with compressed air or pressure water , hope this helps
