Running tailpipes on your track-driven Mustang? Check your fuel lines!
6K views 34 replies 20 participants last post by  fastsvo
#1 · (Edited)
I just had to replace the flex lines between the pump and filter on my 92 5.0, because they had somehow reached the Dynomax 2.5-inch tailpipe frequently enough and/or long enough to create the damage you see below. The one from pump to filter was >this< close to melting through the inner line, and I can only guess that would have cost me one hell of a problem if it had let go. It didn't look like this when I installed the panhard bar last year.
I don't even know how it happened, because I couldn't make them touch with my hands, tugging on the lines, tugging on the exhaust, trying to move the tank, nothing. But they had been making contact, and yes, the exhaust pipe was already wrapped with heat wrap.
Now the new lines are wrapped with heat tape AND wrap, and tied out of the way with an epic display of zip-tie engineering prowess. Even still, you can see the proximity and why there might be a problem.
Edit: Eat my ass, photobucket
  • Like
Reactions: fastsvo
#11 ·
It's not the first time I've had a close call with a fuel line. Years ago I couldn't avoid a big strip of clear plastic sheeting that had falled off a truck on the highway. It got caught up in my driveshaft and all over my mufflers. I pulled over and took off what I could by the side of the road, but there was a driveshaft-speed thumping noise the rest of the way home a few miles away. After it cooled off, I got under the car to remove the rest of the plastic and discovered that the thumping noise was because the spinning plastic had caught the fuel hardline in the trans tunnel and dragged it over against the spinning driveshaft yoke, wearing the line down and almost through...I swear you could read through what was left, but it didn't leak. One more block and it would have pissed fuel all over my hot mufflers.
#7 ·
It's a common failure, especially if you run a lartger aftermarket exhaust.
If you run factory fuel lines and haven't done anything to protect them and get them out of the way, it WILL happen to you sooner or later. Mine happened on the track at Hallett years ago and I ended up with a fine mist of fuel spraying out of the rear wheel.
Tie the lines up out of the way, wrap them in a thermal barrier like Thermotec makes, and wrapping the tailpipe like MFE did would be an excellent idea too.
Me? I eliminated the problem by going to a side exit exhaust.
#8 ·
I've been all over my 03 mach1 and I don't recall seeing any lines that look they could get anywhere near the exhaust.Are the SN95s different that the Fox body or have I just not been looking good enough?
#10 ·
I believe yours uses a returnless fuel delivery system, which is way different.
#9 ·
I had some similar "events" happen a little over a year ago. I changed the fuel pump and didn't put the lines back up in the little gutter around the tank. The line melted on the way home from Disneyland. I also made some Zip-tie "art" with the new line.
#13 ·
I'm a tailpipe diehard. I hate dumps on a street-driven car, plus they heat up the gas tank even worse.
#19 ·
Been there done that... A buddy following me noticed the leak. Replaced the lines, used my trusty zip ties (which I also use to nearly hold the entire car together)and covered it all in alluminum foil.
#20 ·
When I swapped to the bbk 190 lph pump, I had problems fitting it in the 86 basket due to the older design. I had an sn95 basket, and lines laying around, which I ended up using in place of the old lines, and now there is no chance for them to get anywhere near the tails :D
Sorry about bad pic:
#22 ·
MFE I'm with you I ran dumps for about two years after installing all may rear suspension, and I freakin hated it, I always smelt like exhaust. I had the same problem at willow spring big track with the fuel lines, when I was coming off the track the car smelt like fuel. So we jacked it up and we heard a hissing and the fuel was spraying right on the hot tailpipe. So all of us quickly moved away from the car. When it cooled off I found the lines just like in your picture. We ran to the local autoparts store which by the way was a rip off because the track is nearby and bought fuel line to finish the raceday:)
#23 ·
What kind of fuel line did you get, and how did you attach it?
#26 ·
While we're on the subject of fuel lines/back area of the car... What is this plastic hose on my car? It looks like my T/A girdle has bumped it a few times deforming it, but if there is supposed to be fuel in it, there's no leaking. :confused:
(Please ignore my horrible use of RTV on the girdle, my luck sucks at sealing things so I over did it on that).
#27 ·
I had to move the fuel lines out of the way of my Dynomax 2.5" tips this winter when I installed the exhaust system. I ended up taking a section of the metal fuel line out, replaced it with a rubber line and moved it under the frame rail near the point where the panhard bar meets the frame rail on the passenger side. Normally, the metal line sits on the inboard side of the frame rail, which would rub on the exhaust pipe. I put firesleeve over the fuel lines, and put heat wrap around the exhaust pipes near the fuel lines. So far, no issues.
#29 ·
Yes, but I won't be able to get to it right away.
