Run A VCT Deleted Coyote With A Tuned New Edge PCM???
1.7K views 1 reply 2 participants last post by  Turbopgt
#1 ·
As the title states, I'd like to know if it's possible to delete the phasers/VCTs, and run a Coyote engine on an appropriately tuned New Edge PCM? I saw today that MMR makes VCT lockouts and the thought came to my mind that this would be a great option for a Coyote swap on a budget. In theory, all you'd need is to modify your stock harness, locate sensors, and source the usual components to complete the swap. Thoughts?
#2 ·
Definitely possible as long as you give the new edge PCM the inputs its looking for and can mount the mass air/IAT/IAC/and TPS to a throttle body controlled with a cable. Gas engines only need fuel and spark. As long as you can provide that to them it will run. And your obviously not opposed to modifying things to make that happen.
