Okay guys I have a question I have brand new trickflow twisted wedge R heads just sitting in there boxes,brand new crane gold race 1.6 rockers,brand new trickflow stage one cam heres the specs posted below.well what im wondering is will they fit on a stock 302 with stock rods,crank,and pistons without clearance the pistons for the large valve's 2.08 and 1.60,also will the piston to valve clearance be ok with my cam?? And let me tell you what I have planned for the setup im going to be putting a turbo kit on it I plan on running a 76-78mm range with maybe a .68 or .81 exhaust a/r not exactly sure yet,im going to run either 3.27 or 3.55 gears in the rear with a 28 inch tall tire and for the trans im going to run a tremec 3550 faceplated by liberty gears with 26 spline input shaft all done up,the car should weigh somewhere around 2500-2600 with me in it the car is very very light,so are these heads over kill??? if you need anymore info let me know.
Part Number: TFS-51402000
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-5,500
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: HR-224/339-2S-12
