blackout50 said:
The T-5 case is not weak..Where did you guys hear that BS.
On the other hand,Tremec 3550 and TKO case is prone to cracking .!!!
The flex in the in the mainshft is an issue when you get up there.If you reshim your input to 1 -2 thousands end play you will be able to handle quite a bit more
T-5 Cases ARE WEAK, VERY WEAK.
I think not, its called EXPERIENCE
I've had over EIGHT T-5's die in my car over the past 16 years.
I've had TWO T-5 Cases Grenade on me. The last one had GForce parts, and guess what, the Clustergear went out through the case on the passenger side, destroying everything in it. (Biggest waste of money I have ever spent.)
I've since put in a Tremec, and guess what? Been rock solid, no breakages. Tremecs are just plain stronger.
Even FORD ditched the T-5 in favor of the Tremec in the 1995 Cobra R's with a 351. Ford realized they were too weak, so had to put a beefier Tremec into it.
