Powerdyne BD-11a versus initial tuning Powerdyne XB-1A dyno numbers - need some input
I came here to this forum as it seems this is the place where there is the most people that have experience (from back in the day) with the Powerdyne Blowers.
To start off, here is a bit of relevant info regarding my setup
Current Mods on my 2000 Ford Explorer Limited with a 5.0L 302 Windsor: (Keep in mind, I am AWD and using a 4R70W so number compared to the 5.0L Mustang will be lower. The stock 5.0 2nd gen Explorer dynos at about 160 rwhp)
Powerdyne XB-1a Gear Drive Supercharger (Si Trim) with 2.7” Supercharger Pulley and 6.5” Crank Pulley (2023 Production Model)
Custom Water to Air Intercooler
90mm SCT MAF
SR Performance 75mm Throttle Body
Custom 80mm Intake Elbow
1” TrickFlow Intake Spacer
Custom Oil Catch Can
Ford Mustang Cobra IAT Sensor
Ford Mustang GT500 EV6 Fuel Injectors
Walbro 255 lph in tank fuel pump
1997 Ford Explorer Tremor Concept Truck Style aluminum air box
OBX Headers
2.5” Stainless mid X-Pipe between headers and mufflers.
Flex-A-Lite e-fan
Custom built 4R70w transmission connected to a Borg Warner AWD Transfer Case
3.73 rear end
(2) Saleen Borla Stainless Exhaust Systems (true duals configuration) - Saleen XP8 98-0034 and Saleen XP8 00-0023
I've attached three dyno sheets from my experience (so far) with the Powerdyne BD-11a Supercharger and the Powerdyne XB-1A supercharger. Obviously, the dyno results from the XB-1A are just preliminary dyno tuning numbers and I honestly feel there is a considerable amount to pull out of this setup. Hoping the community here can take a look at these past results and give some input
A smoke test was also performed and nothing was noted. We are still investigating what other issues there possible could be.
Obviously, I think we all expected to see a bigger/better result from the XB-1a. At the moment, they do not feel there is a boost leak. They think "maybe" this could be related to belt-slip with the 2.7 pulley and we are further investigating this. Belt tension is going to be checked and additional pulls with the 2.7 and 2.8 pulleys will be made with a full boost level recording (since the dyno boost gauge during the tuning pulls wasn't functioning consistently ) and see where we are at that point.
Thinking based off of the past dyno results of the BD-11a both in stock form and after JB’d initial rebuild - I should be able to achieve 8lbs or more of boost and 350+ RWHP on my setup with the XB-1a.
Some additional info to answer the questions and comments by Jon Bond
The company who bought the Powerdyne rights from 02 Force is now making new Powerdyne XB-1a Superchargers Here is a quote from them - "What had happened was".... the company that bought out Powerdyne was looking for a another company to start re-making the XB again, for them, before they also ultimately threw in the towel as well, and sold out to us...(they just bought the company as an investment, they got in over their heads, they were not very knowledgeable 'car guys' )
They came to us with a proposal, and to TorqStorm - but since we ended up buying them out, TorqStorm couldn't make the XB, as it was, without patent infringement, so they came up with their own version,looselt based on the XB, with different internal sizes, bolt patterns, etc, etc....so it looks similar to a BD / XB, but everything is altered just enough...
Anyway, They made their modified version of it with a much smaller impeller, so they could spin it faster, like a turbo, but it also does not perform well - b/c you cannot spin a turbo sized impeller fast enough , WITH GEARS, to make it reliable. They mainly market it to old school hot rods with old, large motors, but it only makes 5 or 6 pis at best, as well, like the BD. "
Here is the XB-1a that they built for me -
They offer different impellers and trim levels on the new production XB-1A blowers - Quote from them -
"As I stated before the impellers are just like Vortech trims / external sizes, so do your research on the different trim levels Vortech offers, and these are the same albeit slightly different aftermarket designs, but same external dimensions, and you could expect very similar performance.
7/7 fins - best flow at higher rpm, loss at lower rpm
8/8 fins - best flow at mid rpm, closest like stock
16 tall fins - best flow at low to mid range, loss at high rpm "
Here is another guy with an XB-1A that upgraded to a YSi trim level on that blower during a self rebuild?. In the video he says that they make Vortech Parts to fit on the XB-1A. I do not know as much as you do, but you might be able to understand better from the video. He seems to have the and upgraded impeller. He does a comparison between the factory and replacement impeller
Also, more from their build spec sheet regarding Impeller Trim - Quote "A (STOCK) (3.00 ID) - Si Trim (3.08 ID) - T Trim (3.25 ID) - Ti Trim (3.50 ID) - YSi Trim (3.70 ID)
Here is a video of three of the last dyno runs -
Here is a video of the XB-1A just after installation and final fitting -
and just after I received the XB-1A -
instagram.com
90mm SCT MAF
OBX Headers
Flex-A-Lite e-fan
3.73 rear end
- RWHP 303.07 - Torque 336.51
- This was the last dyno of the BD-11A before the rebuild by Jon Bond Performance and original bearing failure.
- I was running the following pulley combo for this pull
- 2.7 (2.65) SC Pulley and 6.5 (6.485) crank pulley
- Stock Impeller, stock belt and stock bearings
- Pull cutoff RPM was ~ 5000 rpm
- Max blower rpm 36,712 - 37,319
- Boost level observed with this pull was right at 6lbs
- RWHP 287.50 - Torque 337.08
- This was the 1st dyno after the rebuild of the BD-11a by Jon Bond Performance
- The following work was done by Jon Bond
- New bearings Billet Impeller New internal belt
- 2.8 (2.86) SC Pulley and 6.5 (6.485) crank pulley
- Pull cutoff RPM was ~ 4800 rpm
- Max blower RPM 33,195 - 33,985
- Boost level observed during this pull was in the high 5lb range.
- RWHP 268.06 - Torque 304.89
- Pull cutoff RPM was 4800 rpm
- 3.1 SC Pulley and 6.5 (6.485) crank pulley
- Max blower RPM 34642 - 34722
- The approximate boost level observed during this pull was in the 4lb range
- The next 3 runs were with the below SC and crank pulley combos
- RWHP 295.31 - Torque 325.30
- Pull cutoff RPM was ~ 5600 rpm
- RWHP 296.17 - Torque 326.34
- RWHP 297.52 - Torque 329.53
- The pulley combo I was running for these (3) pulls was
- Max blower RPM 46511 - 47279
- The approximate boost level observed during the last 3 pulls was in the 6psi to just at 7psi range
Big White Ford Explorer (@bigwhitefordexplorer) • Instagram photos and videos
315 Followers, 87 Following, 219 Posts - See Instagram photos and videos from Big White Ford Explorer (@bigwhitefordexplorer)
