461 - 480 of 1,072 Posts
here's my blown engine bays
Nice trucks!
Weird question, On the Harley is the ac on passenger side of the motor near the bottom? I'm getting ready to buy an AC delete for my 8 rib set up designed for the Harley F-150. I wanted to know if this will work?
Thanks.
Not Sure yet.
Just took off an F1R and air to air that was putting out 750 to the wheels on a superflow dyno.
Now we got an F2 and an water to air... hoping for 900+.
p.s. this is a hydraulic cam street motor.
Cool, I guess it's harder to make power with a hydraulic cam?
Real Street T - Trim 331, etc etc
update : soon to be updated again lol
[/IMG]
Mine is almost finished. I'll be done in a few days and post better pics then but this is how it looks now.
Had to move the radiator since its bigger then stock and the blower is so damn big.
Looks great. How big of a pia is it run the belt with the trick flow intake and the centrifuge SC?
Are still rinning a 6rib setup? How could you do an 8 rib with that intake? I also have an IW crank pulley and a 8 rib set up.
Where did you find the elbow for thr powerpipe to the SC?
I would like the your blower and intake. Hello 700 hp.
Thanks and get up the good work.
The car's a real well used 79 Ghia, was originally a 4-banger. We slotted the k-member and installed a 3.8 V6 with forged rods and pistons, ported split-port cylinder heads, CompCams cam, roller rocker arms, with a fabricated upper intake box-stlye plenum to which we fit a Weiand 144 blower and Holley 700 carb. We had a custom distributor made, slapped on some long tube headers, x-pipe and bullet mufflers. C-4 trans, 5-gallon fuel cell, Aeromotive pump, etc.
Its up and running, great throttle response with 15 PSI, but we have a big idle surge that we haven't figured out the cure to yet.
Maybe it's a bypass issue? Have you been to the track?
