Pinion flange vs Pinion yoke
14K views 23 replies 9 participants last post by  Meegs
#1 ·
In the process of rebuilding my 8.8
Would like to get peoples opinion on going with a stock type pinion flange vs a pinion yoke?
The car already has a stock 8.8 pinion flange, at what power level is this part not a good idea to use
#6 ·
Also, the stock 8.8 flange only allows a 1330 u joint. Some use a 1350/1330 hybrid joint on the DS. Im not a fan of that. After market yokes allow a proper 1350 joint.
#7 ·
The rear end build consists of the following...
33 spline true track limited slip
3.73 gear
9" bearing ends
Billet main caps
Aluminum girdle cover
Tubes fully welded
Based on this build with a chrome moly yoke. How much power should this axle handle without issue?
#13 ·
I use an aftermarket dual pattern steel flange that takes big or small pattern yokes for big or small joints.
I ran the small joint for a little while but changed to a big joint. My car is 3200 lbs. I did a 1.1670 60ft time last weekend.
My 35 spline axle splines have just a little twist in them, but the pinion flange is good and looks like new. To me, the flange looked better than the yoke. I had them both side-by-side and went with a dual pattern flange. The driveline place that built my custom driveshaft also prefers the flange. They do a lot of mud trucks and drag cars in the Atlanta area.
#14 ·
My drive shaft for my Capri that came in my T56 magnum trans kit I am pretty sure is a 1350. It is a real pain to get the bolts in it with the stock flange. The joints are huge compared to stock ones.
#22 ·
That is almost totally backwards.
The flange places the four thick bolts almost entirely in shear. The bolts act like pins in shear, and that is what prevents yoke rotation on the flange. You can grease the joint between the flange and yoke barely have a change in strength. The limiting point in a flange is the strength of the yoke or the splines on the pinion. The four bolts in shear are rated about 25,000 pounds each.
The standard bolted U-joint yoke relies on U bolts in tension to retain the cap. The saddle itself cannot go more than halfway across the cap, so it shares the load equally with the U-bolt. It pushes sideways on one U-bolt leg placing it in shear and tension as the U-joint cap tries to roll out of the saddle.
You have only two smaller bolts in tension and shear trying to do nearly the same job as all four larger bolts on the flat flange joint.
#19 ·
we have been 1.121 60' with the back tires off the gas at .9 @3175lbs with a strange yoke.... it will be fine. the mark williams stuff is nice but some times i wonder if its just the name on some of it
#20 ·
The reason I didn't care for the Strange is because I had to do some careful fitting up with the yoke cap fitments. They didn't come down on the u joint caps properly till I removed some material from the yoke. Maybe they fixed that issue. Other than that it was just fine. But I have run both manufactures front and rear yokes. Just a preference for the Mark Williams. They will both do the same job however if price is the deal maker.
#24 ·
2 flat pieces of metal clamped together by 4 bolts.
The clamping force from the bolts creates friction.
The force of friction is greater than the shear force of the bolts.
The shear force on the bolt is no where near 25,000 each.
