Ohms is a measure of resistance...
So basically when you measure ohms in a spark plug wire, you obviously want the ohms reading as low as possible.
For instance, in my current job we have ground clamps and plugs that have 100ft spools of 12ga. wire inside a coating. When we install new grounding wires or change out a plug or clamp, we have to measure the ohms resistance from the new clamp or plug, all the way to the end of the wire.
Now a perfect reading is 0 ohms, which means there is no resistance in current. But the acceptable range of resistance is 10 ohms maximum. But usually as long as the cable is in tact we usually get readings of 0-1 ohms for a total length of 100ft.
So measure your plug wires and se what you got...Take notice of the different lengths as well. Measure them from the actual terminal lengths, not from the boot ends. For an indiviual wire, measure the ohms, take the total length of the wire and divide the 2. When you have that number, that will tell you how many phms of resistance you have per inch of wire. So let say for example you have 12 inches of wire, with a total resistance of 5 ohms. that is .41 ohms of resistance per inch...no let say you measure another wire that is 18 inches long with a total resistance of 10 ohms. That is 1.8 ohms of resistance per inch...Now the rest of you wires all average between .40 and .50, so you know you got a bad plug wire and you know which one it is.
