O-rings for crossover tube
1 reading
9.1K views 9 replies 5 participants last post by  427-4
#1 ·
Does anyone know off hand what size O-ring is used on the coolant crossover tube. I have a leak at the head/tube on the passenger side, and am 75% sure it needs a new O-ring.
#3 ·
As i read your post..I am looking acroos the desk at a bag of ford o rings. p/n 391533-S100. Oddly.. They come three to a bag.
#6 ·
Ah, that explains it then.(never had one apart to know there was one in the middle)
But does anyone know the size of the rings(local dealership can't get them until Thursday)
#8 ·
I appreciate it. I will take you up on that If I can't get a measurement off of mine.
Thanks.
#10 ·
Coolnat Crossover pipe O ring size
I have had the same problem of leaking Crossover tube O rings.
Nobody knows the size of these... so I decided to research it.
The specs are: "Viton Orings #914 Hydraulic SAE BOSS 7/8"
Make sure you get the Viton material. It has the correct Temperature range and does not absorb Coolant, oils or grease. The diameter of the oring is 0.116" - 0.118"
Viton Orings #914 Hydraulic SAE BOSS 7/8" Price for 10 pcs - Orings and More
I have them installed on my 1999 cobra.
The coolant fill cap is a AS 568-015
This was not an easy find
