no oil pressure - help please
930 views 10 replies 7 participants last post by  Bob Zink
#1 ·
Is there an easy way to determine if no oil pressure is due to a mechanical or electrical problem? I recently had the rear wheels jacked up very high with the front tires still on the ground. I am wondering if the oil driveshaft somehow fell off or something. The oil pressure sender was just replaced 3 weeks ago and was working fine before I jacked up the rear of the car. It is difficult to remove the oil pressure sender to install a mechanical guage or tester. Can anyone think of another way to see if oil is actually flowing thru the engine or not? I was thinking of removing my oil filter while cranking the motor over a few times. I would expect oil to come out if the oil pump is working properly. Any other or better ideas that do not involve removing the oil pressure sender? Thanks
#2 ·
yup, easy way is to get a mechanical pressure gauge from a parts store, home depot, etc and thread it in to where the electrial sender is on the block, just behind the front cover. That is the easiest way to determine if you have oil pressure or not.
#3 ·
Simply jacking the rear of the car up wouldn't cause the oil pump driveshaft to fall out. It can't come out when everything is bolted together unless there is a major problem at hand.
Get a real guage like freaking is saying. Cheap insurance IMO.
#4 ·
When I change my oil, sometimes the first few seconds the engine makes a clacking soud from lack of oil, until the new oil starts circulating. If you really don't have oil flow, i think the valve train would be complaining. Is the engine noisy like the lifters are dry? then I would be suspicious of the oil pump. If it sounds normal, then I would be suspicious of the oil pressure sender, gauge, or wiring.
#5 ·
:( After removing the oil pressure sender and installing a mechanical gauge, there really is no oil pressure. I guess I will be dropping the oil pan to see what I can see. Hopefully, I didn't hurt the bearings as I drove the car for 2/10ths of a mile without oil. The valvetrain wasn't too noisy at all - perhaps because I had synthetic oil in the motor. I just hope I didn't hurt it too bad.:( :( :(
#7 ·
how much time and how many overall miles has this new engine been in the car....???
did you prime / pressurize the oil system when you first started the engine...the very first time....????
the only way that the oil pump drive can fall out or become dis-lodged is if the distributor or the oil pump is removed.....
#9 ·
I bought the car 4 months ago - all the work was done by previous owner. The new DSS engine was installed in 2002 and only has about 5,000 miles on it. I suppose I will have to check the lower rod bearings on #1 and #8 to determine if there is any damage. Is this possible without removing the engine? I have the DSS girdle and windage tray installed - this doesn't sound like fun.
#11 ·
Found the problem - not DSS's fault
Wanted to let everyone know that I found the problem and it wasn't DSS's fault. I found a 1 inch piece of a dipstick jammed inside my oil pump which caused the oil pump driveshaft to break. Now I have to remove some caps to see if I have bearing damage - not fun. :eek:
I suppose a former owner didn't clearance the dipstick for the DSS main support. I can only assume that he knew a piece of the dipstick broke off and decided to not drop the pan to get it. Now it might have cost me an engine.
