Nitrous Kit for a 98 Cobra ????
1 reading
3.6K views 11 replies 6 participants last post by  JAKESNAKE98
#1 ·
Hi,
I have decided to run nitrous on my 98 Cobra. What kit should I get ( NOS, NX) and what else will I need. I want to keep it at 125 shot or under. Not trying to blow anything up. Any comments, suggestions are appreciated. Thank you,
Jake
I forgot, I am getting a dry kit.....
#2 ·
Then you won't be buying the NX kit anytime soon!!!:joy: :joy: :joy:
#3 ·
I ran a NOS Kit #5171(150hp)- switched to a blower and now have the kit for sale. It worked well but was just too hard to control with stock tires. I would highly recommend a flip chip so that you don't have to retard the timing (full time) when you are not running the NOS. You'll need a bottle heater and for a high "cool" factor, an NOS purge kit.
#4 ·
OK, What other kits are out there? I thought NX made a dry kit too. Any other kits besides NOS, or is the NOS kit the best? I am getting a purge kit and will get a bottle heater later. Do I need the window switch? Help me out 96-98 nitrous users.
Jake
#5 ·
Why would NX make a dry kit when wetter is better?!?:D
I think a purge kit on a dry car is kinda...well...dumb. I mean, if all your going for is intimidation factor than by all means get it.
A window switch is good if you like to tach out the motor raicng it. A bottle heater is key if you live in a cool part of the country. There is alot of other stuff you need to know. But we need to know what kit you get to help you out better.
#7 ·
Hocke0233, could you give details about your kit? How much of a shot were you spraying? I'd also like to know what rpms you were at, what gear, and your mods list. Thanks.
#8 ·
i wasn't spraying..
I used the 75-100 shot...
I always sprayed after 3k never over line
Always ran decent fuel.
My mods are full exhaust, 4.10- alum driveshaft, pullies, yada yada
I was using stock fuel pump at the time.
I used the zex kit for close to 2 years now over 50k miles
They just saw my n20 bottle and blammed the spray but I dont know if that was really the case. Dont even fully know whats wrong with it just that it needs to be replaced. My 1 & 2 cynld aren't working at all but still showing 135 when i do a comp test :confused:
What i should have had.
1.Chip/ Timing Adjuster
2. Fuel Press Switch
Have all the other goodies
Sorry to ramble its late and Im looking for a 99-02 GT motor
#9 ·
I like the Nitrous Works kit with the plate that sandwiches in between the TB and the intake. I haven't used it but it looks pretty cool, plus you wouldn't have to drill a hole in your intake tract. I'm not even sure they make them for DOHC's though... Oh yeah, it's a wet kit. I like wet kits because you know you're getting enough fuel as long as it's jetted right. You don't have to rely on just your injectors for fuel. Just a thought.
#11 ·
I too have heard that nitrous works is not only safe to use, but they also list their hp readings in rwhp, so if you get a 100 shot, you actually get 100hp. If I get nitrous I"m with them.
#12 ·
Do they make it for the 32 valve?
