new Comp Cam sbf solid roller XR280,35-771-8
4.2K views 12 replies 4 participants last post by  Ourobos
#1 · (Edited)
new in the box, grind xr280, part # 35-771-8
specs: 242/248 duration @.050, .608/.614 lift on a 110 lobe seperation
you can use stock distrbutor gear with this cam
$230 shipped in the US
SOLD.........
Save
#4 ·
was gonna switch combo to solid roller, but got my hydro roller combo worked out , its just sitting so its up for sale
Save
#7 ·
TTT for ya.
I ran the same setup in my 351w. Had a nice racy idle at around 850-900 rpm. Pulled very hard to 6500, but still could be lugged around town at 1500-2000 rpm (carbed combo with 3500 stall converter).
#9 ·
I have some camshafts new very similar. Both from comp cams one is the same as yours except hyd roller and small base circle with 108 lca.
the other is hyd roller too with 110 lca and 236 242 @.050 any chance you interrested in a trade or you need something else? I have lots of 5.0/5.8 parts
Javier
Save
#10 ·
what's the lift specs on the cams, also looking for headers for aod foxbody, intakes , throttle body, mass air meters, injectors. let me know what you have!
Save
#11 · (Edited)
FW 3150/3170HR108 SM BC
open close
intake 17 47
exhaust 55 13
duration @.050
intake 244
exhaust 248
Lobe sep 108
cam installed @ 105 intake cl
lobe lift .361 both intake and exhaust .577 lift with 1.6 ratio
may have a set of mac long tubes that may fit also
Javier
Save
