New Bilstein HD struts on a Fox Body - Strut mounting ear holes
1 reading
2.2K views 6 replies 5 participants last post by  10Boom
#1 ·
Question about using Bilstein HD front struts on a Fox Body. The struts are designed for 87 - 2004 mustangs.
The lower bolt hole on the mounting ear attachment to the spindle is bigger than the top hole.
This allows for some movement / slop when the old bolt is being reused.
How do people align the strut before tightening the lower bolts? Is it where ever it ends up and torque it?
Should I use a different bolt on the bottom hole?
I am also installing MM caster camber plates at the same time.
Thanks!
#2 ·
Push the top of the spindle in to take out the slack and tighten the bolts. I did mine that was and it aligned fine. I'm also running MM plates.
#4 ·
ditto, I pushed mine in I believe also and just adjusted my plates as needed.
