You running 6000 rpm alot, for long periods? Frankly, I've used the stock dizzy on blower, nitrous and turbo apps without difficulty, with 6000 rpm as max, and only briefly. If you are into an application that needs sustained high rpm, it's probably worth it to upgrade the distributor to reduce spark scatter but otherwise, money is best spent elsewhere, imho.
