Moroso rear springs?
3.4K views 10 replies 9 participants last post by  cocomojak
#1 ·
Has anyone tried the Moroso rear drag springs? The ones with a heavier right spring rate? I am considering buying them and would like some input. Thanks in advance.
#2 ·
I have a set on my car now. I had to cut 1.5 off to get the right ride height. But make sure you let the springs settle before you go wacking them off left and right.
#3 ·
I have them on my car, they were installed by the previous owner, they raise the rear up a bit, I havnt cut mine but I might, everybody gives me crap about it to cause it sits so high!!
#5 ·
Travel is what I don't want. I am having a tire rub issue now. Are the spring rates that much softer than stock?
#6 ·
Stock springs are 160 lbs.
I went 1.43 with stock springs, Baseline ARB, steeda adjustable uppers with poly bushings, baseline single adjustable lowers with solid bushing, Strange 10 way adjustable rear shocks.
Get some adjustable struts if you don't have them already and see if they can help with the squat problem.
