21 - 40 of 75 Posts
I see you have some great prices on forged internal standard stroke shortblocks as well. Would the MMR 4.6 Street Mod 900 shortblock be solid under say 12 pounds on intercooled boost daily driven? Also what sort of power would that make to the ground through a tremec 3650? I'm interested in buying right away.
Save
Discussion starter · #31 ·
12 Pounds on a daily driven car would be a walk in the park for our Street Mod 900, a 3650 will handle about 500HP on slicks a few times, we have seen them last quite a while on street tires/drag radials. Let us know how we can help.
MMR Tech
MMR 5.0 STROKER Street Mod 950 $3699
*New Cast Iron 2003-04 Cobra Block (Romeo)
*New 4340 Forged 3.750 stroke Crankshaft w/micro polished journals at no extra charge STANDARD JOURNAL SIZE (NOT HONDA)
*New 4340 Forged H-beam Rods
*New Forged CP pistons 3.552 Bore size (High or low compression)
*Speed Pro file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A)
*Speed Pro/Federal Mogul Rod and Main bearings
*Complete Pro Assembly and Balancing for the smoothest, highest revving shortblock available.
With an Aluminum block how huch hp will this support?
What kind of rods are in this?
Discussion starter · #33 ·
The aluminum block will support roughly the same power level, the stroker 950 uses 4340 Forged H-beam Rods made by Eagle, this rod has proven itself to support over 1000 HP in this application.
I saw someone else asked this, but if I have a brand new 03 block and the heads and everything can you build me a long block, and me send you a long block? I do not have alot of down time available. How much would we be looking at? Just a guess would be ok. 03 block brand new. Stock heads with about 60,000 miles on them. I might be needing a long block. I would like aftermarket cams in it also. Send me a e-mail and I can tell you the specs on everything. Thanks aaron427@msn.com
Save
why oh why can't you guys be on the east coast!? your prices are the best on the planet but adding shipping to NC forces me to go with someone else. guys thinking about branching out anytime soon...LOL...please...
Save
21 - 40 of 75 Posts
