Status
Not open for further replies.
Mallory 4060FI - Comp Fuel Pump
1 reading
570 views 2 replies 1 participant last post by  SScott
#1 · (Edited)
SOLD to BMF03... Thanks!
It is almost new. Will take $75 shipped or trade for bypass reg with boost ref. for carb.
Sells for $170 on Summit
Info from summit:
Free Flow Rate 60 gph
Maximum Pressure (psi) 55 psi
Inlet Size 3/8 in. NPT
Inlet Quantity Single
Inlet Attachment Female threads
Outlet Size 3/8 in. NPT
Outlet Quantity Single
Outlet Attachment Female threads
Quantity Sold individually.
These Comp Pump series electric fuel pumps are ideal for high performance street or race applications. They have a high-quality, permanent-magnet 12 V electric motor and feature factory-set base pressure. Intended for gasoline use, each pump assembly features a quiet, high-efficiency Gerotor design that provides stable output. The housings are fully machined and have a special design that allows for some adjustment of the output pressure. All Comp Pump series fuel pumps must be used with a fuel pressure regulator. The pumps are available in many different ratings, from 60 to 500 gph, with fuel pressure ranging from 4 to 100 psi. They're perfect for any carbureted or fuel injected engine!
Save
Status
