Low pressure in tank fuel pump
5.6K views 11 replies 8 participants last post by  SilverHeals
#1 ·
Does anybody have any suggestion or leads on a 8-9 PSI In tank electric fuel pump? I am in the middle of a restomod for a 66 coupe with a 351W and a 4 barrel Edelbrock carb.
#2 ·
I don’t know of any in tank pumps that put out 9lb or less. You can run pretty much and efi pump you want, if you regulate it with a good bypass regulator and good sized return line.
#3 ·
I was thinking the same, I don't know of an EFI in tank pump that puts out 9 psi or below. Can use a standard EFI in tank pump and a compatible regulator that can lower the pressure to ~9 PSI.
#4 ·
#6 ·
