It won't rev past 4800 RPM, I'm TOTALLY out of ideas. PLEASE HELP!!!!
Hi fella's. I've got a 1991 Mustang GT vert, 5-speed. I bought it wrecked, and I've been fixing the damage. The motor has done this since day one. Here's my problem, it WILL NOT rev past 4800-5000 RPM's, it's like it hits a brick wall, just will climb fine then slam into it, sounds just like a rev limiter,. It hits it an WILL NOT got any further. It's driving me nuts!!!
I've replaced the distributor, TFI module, coil, plugs, plug wires, new cap and rotor, valve springs, tried two different known working EEC's, put a aftermarket tach on it to verify that stocker was correct (it was). It shows 42psi of fuel pressure at WOT. I checked the firing order several times, it's right
About the only thing I haven't done is replace the fuel filter or replace my whineing fuel pump, but I'm showing good fuel pressure so that can't be it.
Does anybody out there have the slightest clue what could be wrong with my motor???
Please help,
Josh, aka the tireburner
Please help,
