I mess with small stuff on a daily basis. A large majority of stuff I do is fuel system related (speaking of gasoline engines only).
I hear/see this stuff all the time. "All I buy is 100% gasoline, with no ethanol"...and yet they're at the shop with a plugged carburetor or fuel pump issues or whatever. They all say the same thing, they don't let 'em sit and they are used often.
But what I've come up with is that all fuel-E10 included-sucks.
The EPA mandates gas stations to label the pumps "up to 10% ethanol" if the Ethanol content is more than 7%. Besides that, in all my testing (with the correct testing strips), we see average of around 5% Ethanol from the same station that we get our shop gas at, which is supposed to be 100% gasoline. But it's not. Perhaps the EPA doesn't require it to be labeled unless it's over 5%? Dunno.
Last week I tried an experiment. I have a pint jar at work that I use for fuel sampling. I filled it about 3/4 full and let it settle down, then marked the level with a sharpie. Let it sit about 3 hours and came back just about quitting time, and a good portion of it has evaporated. I'd guess about 40% of it. It wasn't sitting in the sun, in the shop, fans blowing air around, temp in the shop was about 85°F. It tested around 5% Ethanol.
Something else I've noticed is comparing fuel system issues vs what kind of gas they run. It seems that there is no difference. About half say they run non-ethanol, the other half say they just buy whatever's available. Thus, I don't get real picky with fuel. I buy what's most convenient unless it's known to have problems (water, etc). If'n I need top quality because I have a tune up that's on the ragged edge, I'll buy race fuel of whatever sorts. My brother's switched his stuff to E85 and seems to like it but it's not consistent, so he has to buy a lot at a time (drum).
