Some of this is going to greatly vary depending on the combo used to produce those numbers. Running a N/A setup will obviously require far less fuel as you are only aiming for an ~ 12.5:1 AFR at full load/wot. A turbo setup would be next, and will typically run out of fuel in the low-mid 500rwhp range with a HP255 pump, stock lines/rails and an ~ 11.5:1 AFR. Superchargers because of their extra parasitic drag are typically run out of steam a bit earlier and are typically good for 450-500rwhp with ~ 11.5:1 AFR’s.
With that said, if you have a $h^% tune and are running around with a 10:1 AFR…you’re going to run out of fuel quicker. Does that mean you need bigger lines and rails? Hell no it doesn’t, it just means you need a proper tune!
I myself am right around 500rwhp with a single gss340, stock lines and rails and an even 11.5:1 AFR across the board.
