How far will I get on 80lb injectors
1 reading
21K views 21 replies 10 participants last post by  stangjumper
#1 ·
I've heard I can make 1000hp at the wheels on 80s, is this true? What kind of numbers are people seeing? I wanted the billet atomizers but without a standalone ecu or an injector driver I can't run them. Plus the cost to get the injectors with a driver was $1500+. The way my budget is looking for this build and because of the desire to get the car running ASAP, I decided to go with the seimans deka 80s for now. I'm planning to run C16 as fuel and also this is through a manual transmission. What do you think and will I have issues with these injectors?
#4 ·
I was tapped out at 800RW on 80s @ 100% duty cycle and 55psi base fuel pressure
fuel pump was a magnafuel 750 too...
#5 ·
you can get 120's and an injector driver for $800...I used that setup before and could have made 1000RW through a stick
#21 ·
Im selling my bosch low impedance 160's for $450. Nothing wrong with them, just had to move up to 225's. Buy a driver and youll be good to 1100ish on E85. Youll save the money in fuel cost over that C16 quick!
