I have a Holley Terminator X foxbody kit ordered that I am waiting to arrive. I have been doing as much research as I can in anticipation of the install, as well have a friend with a Holley HP setup in his car that I helped a bit with, so I have a good idea of whats needed but had two questions that I could not find the answers to yet. The Terminator X has been out for a while for the LS's but the foxbody kit is fairly new and I haven't found as much hands on install info yet.
A little background info on the combo if needed, its a 1992 5.0 Mustang;
Holley Terminator X Foxbody kit (550-937F), Can to USB cable, GM 3bar MAP sensor (12592525), Areomotive adjustable fuel pressure regulator, a fuel pressure transducer and Deka 60lb/hr high impedance fuel injectors.
I have read the instructions and various posts on the install, my questions are;
- In the harness manual for the 550-937F in regards to the fuel pump relay, it says "The factory fuel pump wire can be cut or removed from the relay and connected to the loose Green fuel pump wire in the Holley main harness" and it shows a picture of cutting the pink wire from the factory fuel pump relay under the drivers seat and connecting the loose green wire from the Holley harness. That is easy enough and makes sense and is how my friend wired his in his 89 mustang. My Mustang is a 1992 and the 92-93's factory fuel pump relays are located on the passenger shock tower and are part of the ecm harness which will be removed. Where do I attach the loose green power wire from the Holley harness to power my fuel pump in my 92?
- In the install manual for 550-937F it makes no reference to where the physical timing should be set at. It shows pictures of selecting a wot timing figure at 0 boost and a timing retard figure per lb of boost in the setup wizard on the 3.5" handheld but does not mention what the distributor should be physically set at or how to sync so that the Holley ecm knows what the timing is set at in relation to what its controlling.
Thanks for any help, I have been reading like crazy and excited to get my Terminator X soon and start on the install.
- Previously combo was stock bottom end, stock heads, stock cam with a Trick Flow intake and a Vortech A-trim supercharger with a 255lph in tank pump, 36lb injectors and calibrated MAF. It ran good and I drove it regularly on the street for two years including running it at the track twice. It was a stock A9L ecm with NO tune but I did have a wide band to monitor A/F ratios and timing was set conservatively (10deg base with spout out) and ran on 93 octane
- I have now just added Trick Flow 170cc twisted wedge heads, 1.6 roller rockers and a TFS stage 1 cam. The car is back together after the heads/cam swap and runs but the A/F ratios aren't where they should be and I realize I was lucky the car ran as good as it did before without a tune but now is the time to upgrade to Holley efi over the stock ecm.
