Holley aluminum heads
18K views 19 replies 11 participants last post by  Hawaii5.O
#1 ·
New to this forum, great recourse! Hope I'm posting in the right subsection. I picked up a motor with a set of holley 12116 heads and I'm tryin to get information about them but I can't find any. Has anyone ever had a set or know where I can get specs on these heads? Aloha and mahalo
#5 ·
huh?
Holley used an inline valve configuration, not a rotated valve.
The castings could be Brodix or Buddy Bar.
Valve angles were 17 or 20 degree depending on the series.
The only guide issues were due to stupid people installing them without checking valvetrain geometry. That is a possibility with any cylinder head.
I've done quite a few of these Holley heads and they do work well with modern upgrades.
#7 ·
#11 · (Edited)
stock explorer block with a B-cam and a set of 1.7 rr. And it's carbureted...
The B-cam is the pinnacle of automotive engineering! And the B-cam is the pinnacle of all technology that has ever been done, or will be done!
Just ask Ed! Even he will tell you that none of his custom cams come CLOSE to comparing to the B-cam! (THANK GOODNESS! :))
NOTE: NSFW because of some language.
All hail the all mightily B-CAM!
BTW, there's come great cr*p, opps I mean stuff, they sell on the interweb that allows you to run an engine without any oil at all!
IMHO, that stuff and the B-cam were made for the same people.
All hail the all mightily B-CAM! :)
#13 · (Edited)
I have the full systemax 2 kit, heads work pretty well, I thing it's a 165cc with with 2.02/1.6 valves. But I could be wrong it's been a long time since I looked it up. The systemax 2 are stud mount and the original ones were pedestal. Your best bet is to call Holley and give them the part number and they'll give you specs.
Oh and do yourself a favor and get a custom grind.
#19 ·
The set I had came with 7/16 head bolt holes so if yours are the same you'll need to drill them out to accept the 351's 1/2 head bolt holes. Any machine shop should be able to do it for not much $.
