I have a 1991 notchback that I'm installing a MM extreme duty adj lower control arms, tq arm and panhard bar setup. I started to install the lower control arms and noticed that the bolt holes are oblong, there seems to be about a 1/16" to 1/8" too big. I have the correct bolts they are the 12mm ones. I took off some south side lower control arms which came on the car and I'm not sure if they caused this to happen or what. I need to know if this is suppose to be this loose or is this something that needs to be repaired? This is my daily driver in the summertime, has a single turbo shooting for 550-600 at the tires. If I'm supposed to fix this how would you go about doing that? Thanks, Karl
