GT40Y VS World Products Windsor Sr. Heads
9.4K views 10 replies 6 participants last post by  1980cobra
#1 ·
I have a quick question, I recently acquired a set of World Products Windsor Sr heads. I have a set of slightly worked GT 40Y heads on my 351W right now, would it be worth the effort to swap out the heads on this motor? Thanks
#3 ·
Gt40y's only flow about 214 slighty better then windsor jrs and gt40ps. Really only great for 302 based applications. They can be hand or cnc ported just ike anything else but Im not sure of what you can make them do Im sure there plenty of room for better numbers. There not bad for what there intented for when they were made I like mine.
#7 ·
I posed the same question and was told that the Sr's have more room to grow. They flow pretty well with some bowl blending, but work much better on a bigger cube motor. I think you would see some gains from them, but there are much better choices out there.......
#8 ·
Roger, Iunderstand that there are better choices but the thing is that I have these sitting in my garage and they were free, so would it be worth swapping the heads? I want to say that the guy that gave me these took them off of a 408 and he was using a 351 super victor single plane and an AED 1050 but swapped the heads to the man o war aluminums, I cant really remember how well it ran in that setup. i was just thinking that if he was running them on a 408 that they would run a little better than my 40's
