So recently bought a set of gt40p heads to install on a foxbody 5.0 but I want to know what do I need to do or replace before installing. Motors pretty stock but adding gt40 intake on top I just want it to run good and fun.
There is a port offset issue as well compared to all aftermarket heads which have their exhaust ports centered between the bolt holes, generally, unless they use the unique patterns for some of the Trick Flow heads and others.What???
The difference is the sparkplug angle/location.
