gt40 intakes egr or non internal egr tell the difference
1 reading
28K views 16 replies 8 participants last post by  88 5.0coupe
#1 ·
i got 2 sets of gt 40 intakes and both seem to be a lil different how do you tell which is which and which is better to put on a 5.0 mustang or it doesnt matter both will work?
#2 ·
If you want internal egr simply look at the lower and upper interface. There'll be a hole dead center of each (4 ports on one side of the small hole and 4 on the other) where the exhaust gas moves from the heads through the lower and into the upper. If it's there - you're egr internal ready. If it's not.... Here's mine - note there is NO HOLE between the front 4 ports and rear 4 - this lower is NOT egr ready.
#6 ·
ok i got one set on the car already it was on when i got it, not sure if it has the hole or not i just know there is more vacuum ports and the shape from the plenum to the tb is a lil different. the other gt 40 i have has the hole in the lower but the upper is blocked. are they both ok to use? all my egr is deleted off the car anyways..
#8 ·
If your egr is deleted - then I'd use at least the upper without a hole - to keep exhaust gas heat as far away from the upper as possible. If you can find a lower AND upper without the passages - even less heat. If the lower is missing the hole - doesn't matter which upper you use as you've cut the exhaust path off at the head.
#9 ·
Explorer intake with Internal EGR will have -BA at the end of the part number on the lower intake.
Explorer intake without internal EGR will have -BB at the end. If you look at the intake above...it says -BB
Also....just look for the EGR hole
Left is late model explorer...right is early model
#12 ·
i was going to run the t moss ported internal egr lower with my non internal upper, guess ill just have to go sandblast the other 2 intakes and use them hate doing things twice lol
