FS: Edelbrock Performer RPM manifold, Girdle, rocker studs...
570 views 21 replies 6 participants last post by  alc24073
#1 · (Edited)
Changing setups have a few parts i dont need anymore...
Edelbrock RPM upper manifold and performer lower- In good condition, a few small scratches and one corner has a little paint missing, comes with all bolts/studs/nuts and gasket for upper to lower, none of the bolt corners were ever broken on the upper from overtightening... lower is a little dirty needs a little cleaning- $300 OBO *SOLD*
Trick Flow Stage 3 Camshaft (TFS-51402002)
Cam Style: Hydraulic roller tappet , Basic Operating RPM Range: 3,200-6,800 RPM , Intake Duration 050 inch Lift: 236 , Exhaust Duration 050 inch Lift: 248
Duration at 050 inch Lift: 236 int./248 exh. , Advertised Intake Duration: 298,
Advertised Exhaust Duration: 310 , Advertised Duration: 298 int./310 exh. ,
Intake Valve Lift with Factory Rocker Arm Ratio: 0.574 , Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.595 , Lobe Separation (degrees): 110, Brand new-$160 retail, $115
Hawks Racing steel main girdle for 302 main caps-brand new never used, got an extra one in plans to do another 302 motor but never got around to it, zinc coated, 5140 high strength studs, all nuts and washers included and instructions with torque specs- $70 * SOLD *
3/8 upper to 7/16lower ARP rocker studs(set of 16)-the 7/16 side bolts into the head so you can 3/8 rockers, for FORD heads, used once in great condition-$15
PM, email me det12585@yahoo.com, or leave a reply, thanks
Have pictures as well i can email...
Save
