Looking to convert from my 5 speed to an AOD. These are the two companies I have contacted for estimates. Looking for your opinions. My car is in my signature.
What Lentech said:
If you mustang is a limited street car with possible further power increases then I recommend the Strip Terminator @ $3295. If you are going to the track with slicks you will likely want the full manual transbrake option @ $400. We have a 9.5” converter with aluminum stator and very thick forged front cover for $845 that will handle up to 900 hp. You will need a 2step rev limiter with a transbrake.
As far as other install items required we don’t make any of our own accessories or specific swap kits for your fox mustang but as I’m sure your aware they can be sourced from many local suppliers. You will need to change your slip yoke to a 28 spline t-5 type and your cross member and mount will work. If you place an order with Lentech I am certainly willing to make further detailed recommendations.
What Freddie Brown said:
Thank you for your interest in our transmissions based on the power your car is making we would recommend our full manual Pro Street/Strip 4STB for your 1991 Mustang. Our 4STB does not require a TV cable.
The total package price with converter will run you $4590.00 shipping included.
Here is what you will be getting.
300M input shaft
Competitiion Hi flow Manual Valvebody & high pressure regulator
HD Intermediate Mechanical Diode Assembly
Hi performance clutch packs & high energy band
Large servo Assembly
Modified Front Pump Assembly with Teflon Rings
Stamp Steel Drum
OD relay controller
Dip stick & tube
Cooler
Braided cooling lines with fittings
HD Spicer Yoke C-4
Quarter Stick Shifter
10" Street Strip Converter
The list is complete of parts you would need. Transbrake is an option we can add its an additional $210.00 and yes its electronically activated.
300M input shaft
Stamp Steel Drum
OD relay controller
Dip stick & tube
Cooler
HD Spicer Yoke C-4
