foxbody Mustangs with saleen 18x9 ,18x10 post up your pics
2 reading
238K views 156 replies 73 participants last post by  Unterj1
#1 ·
looking for some pics of saleens on a foxbody . please list tire size, backspacing and offset thanks
if you have 17's post hem up also
#3 ·
Here are mine:
Front:
99 Spindles 18x9 Saleen Rims with 24 MM offset Tires are 265/35 Pirelli P-Zero's
Rear:
Stock Fox length axels, North Race Car caliper brackets. 18x10 Saleen Rims with 30 MM offset and 295/35 Pirelli P-Zeros.
#156 ·
Here are mine:
Front:
Rear:
did u have to do anything to the rear to fit that tire n wheel? That’s exactly what I wanna do just not sure if I should go down a width size on the rear
#8 ·
That is what the authentic Saleen 10" wide rims came in. I did not mod the wheel wells at all. Saleen rolled the fender lips but other than that the wheel wells are as Ford delivered them. I thought for sure I would need the BFH on the inside. I have a Magnaflow exhaust that was not touched. There are no quad shocks on there however.
#18 · (Edited)
That's mine lol
Here's a more recent set
Specs:
Front: svo 5lug conversion, 18x9 Saleen wheels, 24mm offset, 255/35r18, NEX full coilovers
Rear: complete 98cobra rearend, 18x9 Sallen wheels, 36mm offset, 275/35r18, Titanium NEX rear shock w/ MM adj. LCA & Eibach blue drag launch springs(yes w/ 98cobra rear end the axles stick out, this is why only a 9inch wheel with 36mm offset is used).
http://img523.imageshack.us/my.php?image=3-23-08017.jpg
http://img523.imageshack.us/my.php?image=3-23-08019.jpg
http://img523.imageshack.us/img523/2252/11-17-08018.jpg
http://img523.imageshack.us/my.php?image=11-17-08012.jpg
http://img523.imageshack.us/my.php?image=11-17-08010.jpg
http://img523.imageshack.us/my.php?image=morejacen052.jpg
Also, here's a vid of my build somewhat
http://www.youtube.com/watch?v=GI7Qo75bX6Q
#19 ·
MR. STALLION ..i am also using eibach blue drag springs , did you cut your front drag springs?? your car is bad ass.:king:..i am going use stock lenght axles when i do my rear brakes . i plan on running m/t sportsman s/r 26-12-18 in the rear with a 18x10 22mm offset and 6.35 bs
thanks for the pics
#153 ·
#53 ·
the car does have c/c plates on it..just for some reason the saleens stick out...the car has a 18x9.5 on it now and they dont stick out..they line up good...
As in lined up inside the fender, because unless its an optical illusion it looks dead even with the outer fender. So whats it like on a bump
