Read this thread before. I'm considering this, but just want to see if they're any other ideas out there.
Did you ever finish your p/s rack setup?
dang that sucks, im assuming you would use a longer line as well to get it off that heat source at the same time. i bet thats boiling the fluid!
Trying to prevent any possible damage before it gets up and rolling. We started the car, just no driving yet.
I see you have an electric water pump might, as well go electric steering pump as well /forums/images/smilies/wink.gif
Different platform but there are braided lines for the e46 M3 that ended up causing the pumps to go out due to a smaller ID than the OE lines. Check those ID sizes
I considered electric p/s system also. If you got any additional insight/info to share, that'd be great.
I did see some guys talking about Volvo having electric pump (ford brand) you could use, but it seemed to be more work involved than what I am willing to tackle....lol.)
Using the factory routing of the stock rubber line would give all the clearance you need.
Good luck
That's a stock power steering line. How would routing a stock rubber line give me more clearance?
Does any one know the thread pitch & size of the fitting that goes into the pump? Both side & bottom?
Going to order Maximum Motorsports AN fittings today
