I am putting my 9.5" deck windsor back together for some fun this summer and thought we could use some content around here. My goal is to have this thing running this spring for some of the events we have around the Dallas area.
The engine is made up of:
Ford Racing 4.040" bore 9.5" deck N block - wet sump, cleveland mains, 4 bolts on center three main caps
4.0" stroke Eagle crank
6.2" Eagle rods
JE flat top pistons
Ed Curtis special - Flowtech Stage IV solid roller 3/4 race B cam (around .700 lift and 250-260 duration)
Comp Cams 967879B-16, .875" diameter, .050" offset on the intake
Trick Flow 3/8" moly pushrods, 8.750" and 8.800"
Danny Bee belt drive
Brodix 15 degree head hunter heads, 2.15/1.625 valves, 62 cc chamber, CNC ported by Kuntz Power, this is their small valve port since the 4.040" shrouds the valve
Edelbrock Super Victor intake manifold 29245 ported by Kuntz Power with 105mm throttle body
T&D shaft mount rockers, 1.7 ratio, steel exhaust rocker
The engine will be 11.0:1 static compression and run on E98 along with a Procharger F2 making ~20 psi at 7000 rpm.
The transmission is a BTE top sportsman powerglide with a Chance bolt together steel converter that stalls to 4400 rpm on the brake.
Engine management is a Holley Dominator setup with dual O2 sensors
Fuel system consists of Holley 160 lb injectors and an Aeromotive 5.0 brushless pump.
In the prior iteration this engine had 225cc Twisted Wedge R heads and a cam that was less ideal. It was fast enough to have fun and did around 9.40s@145mph and 6.0s in the 1/8th mile. It did tend to run out of steam at about 6800 rpm and was right near that when going through the lights at the end of the track. As part of this upgrade, I wanted to extend useable rpm to 7200 or so. My only real goal here is to go as fast as possible without grenading the externally balanced bottom end.
I will post more pics as they become available.
6.2" Eagle rods
JE flat top pistons
