I have started repairing them, just repaired mine, three burned traces. I have also put together a bench testing box, if local I can hook your vehicle to the ford eec-iv monitor which allows me to look at each input/output on the 60 pin connector to verify proper function. In the case of my ecm, car ran with driveability issues I could not tune out with binary editor. . .when I opened the ecm, I discover one of the caps leaked all over the board and created an open on the spout circuit, seriously damaged the vpwr circuit, and shorted the resistor array. While the car started and ran, my new 11:1 compession 331 with afr 195s, and ultradyne/bullet cam .588" 231 deg@ .050" would pnly push car to 95 mph in1/4 mile, it wasn't advancing timing. These ecms are at the age they need to be gone through. My ig is the same as my handle here. You can see my ecm progress there.
