manifold vacuum b303 cam
TO Matt,Hi I have a 302 EFI SET UP IN AN 85 LX, WITH THE B303 CAM AT IDEL I GET 13 -15 HG.
I Had to install a vacuum reserve tank from crane cams, plus installed check valve off intake manifold, plus installed a gauge to see current vacuum readings.
Now vacuum is up to 16-21hg with the reserve.
My latest thing is the install of the electric vacuum pump from stainless steel brakes,purchased thru summit racing.
Vacuum is now constant with 85 stock brake booster at 21hg, its still in series with vacuum reserve tank.
My mastercylinder is svo 1-1/8 bore with 73mm fronts and baer rear brakes.
I hope this helps ,if you have any questions ,you can call me at 561-683-6257 ask for Big mike .
