My project has been slow, but should be done in the next month. :joy:
Started last year with a need to replace a fender. Ended up painting the whole car. Smoothed the engine bay and painted it as well.
Welding - PSI Racing
Paint - Bryan's Auto
Click pics to enlarge
Someone offered to buy my TW heads and D1SC and this project snowballed from there.
Did the Maximum Kmember, switched to Coilovers up front, '01 Cobra brakes & spindles.
Maximum parts:
MM K-Member, 1979-95 with 4.6L modular or
2011+ Coyote engine
MMFCA-1,2 MM Front Control Arms, 1979-93, Non-offset (Stock
Geometry)
1 MMFCAB-1 Urethane Bushing kit for MMFCA's
MMTR-1 MM Tie-Rod End Kit, 1979-93 aftermarket
K-Member (bolt-through spindle)
1 MMCO-2 MM Front Coil-Over Kit, Tokico/Koni Struts
1 MMST-6 MM Steering Rack Bushings, MM K-Member
1 19-413-BL Sway Bar End Links, 1979-93, Short
HYP27510250 Hypercoil Coil Over Spring, 275 lb/in, 10", 2-1/2"
dia.
1 6-1126-BL Front sway bar bushings, 1-5/16"
2 51651-rear H&R Sport rear spring, each
DSP-11 Tokico D-Spec Kit, 1987-93 Mustang, set of 4 (2
struts and 2 shocks)
Already had Baer rear disc brakes so I got their front rotors to match. Had the electric and brake lines all run through the fender.
Proportioning valve and line lock (manual brakes):
Wires to the fender:
I had to read through a lot of threads and posts to find some of tricks to make this work.
OSS sensor: http://forums.corral.net/forums/gt-sohc/1322700-ffrp-coyote-5-0-crate-engine-swaps-suck-4.html
http://forums.corral.net/forums/mem...ber-build-up-projects/1405699-foxbody-coyote-5-0-swap-engine-bay-smoothing.html
A alternator wiring issue from: Coyote swap - Page 6 - Four Eyed Forums
If anyone has any other resources to add that would be great.
Swap parts from Late model:
LRS-7007D – 96-10 MUSTANG 4.6L Manual Bellhousing Spacer Plate
M7771A – 1996-10 MUSTANG 4.6L Bellhousing Bolt Kit
2011-13 MUSTANG FORD RACING 5.0 Coyote Motor
M6017A504V – 2011-2013 MUSTANG FORD RACING Control Pack
M8600M50BALT – 2011-2012 MUSTANG FORD RACING Alternator kit
BBK-1787 – 79-93 MUSTANG BBK 5.0L COYOTE X pipe
BBK-16340 – 79-04 MUSTANG BBK CERAMIC COYOte long tubes
MOR-20571 – 1979-2010 MUSTANG 5.0l COYOTE Oil pan
Got a new black top as well.
More pics to come.
Maximum parts:
2011+ Coyote engine
Geometry)
dia.
More pics to come.
